Bitcoin was to revolutionize the financial segment as Satoshi Nakamoto, the Bitcoin developer, created a decentralized and alternate payment method. However, due to intense price swings in the market valuation of bitcoin, no one is considered an actual currency. Traders and investors noticed the potential in bitcoin as a speculative investment and trading instrument.
 Bitcoin is the utmost demanding currency or an investment asset as the finite supply of bitcoin is inclining its scarcity. To get in-depth information about bitcoin trading and its insights, like this Platform.  Bitcoin works on an entirely virtual network, and it has nothing to do with the land-based progression except bitcoin mining. Bitcoin mining is also a virtual action, but it requires an actual computer.
We know that the cryptocurrency market has evolved immensely in this decade, and you can now store your cryptocurrency assets on your android device. However, several stakeholders are concerned about holding bitcoins in android devices. So, let’s find out whether it is safe to store bitcoin on an android device and understand the steps to transfer a bitcoin from one wallet to another wallet.
Difference Between Spot Wallet and a Dedicated Bitcoin Wallet!
Bitcoin wallets are of different types, and some of these types are hardware bitcoin wallets, dedicated android bitcoin wallets, spot bitcoin wallets, a cloud bitcoin wallet, and desktop bitcoin wallets. People mostly confuse android based bitcoin wallets with the spot bitcoin wallet. However, spot wallets and dedicated bitcoin wallets are different from each other.
Spot bitcoin wallet is the wallet provided by a bitcoin exchange, and you can instantly transfer your cryptocurrency assets from the spot wallet to any other wallet. Spot wallets are accessible only if you log into the cryptocurrency exchange and cannot access them separately. On the other hand, dedicated android wallets are not redirected or linked with any exchange. Compared to spot wallets, android-based dedicated bitcoin wallets are very secure as they utilize a robust security protocol.
We have a Dedicated Android-Based Bitcoin Wallet!
Spot wallet and dedicated android based bitcoin wallet are entirely compatible with android devices, but as discussed above, there are some differences between them. Android dedicated wallets are better than spot wallets as these wallets are much more secure than spot wallets. Features of the android-based wallets include convenience, accessibility, fast transactions, high-speed transactions, and computability with low processor android devices.
Spot wallet and cloud wallets are also compatible with Android devices as you can use them with any search engine. However, you should be familiar with the fact that cloud-based bitcoin wallets are the least secure bitcoin wallets.
You must avoid storing your cryptocurrency asset in these cloud-based wallets as they are exposed to vulnerable hacking elements. Cloud-based wallets are free of cost, but you can lose your entire cryptocurrency holding in these wallets.
In a nutshell, you can store your cryptocurrencies asset on an android device, but you should only choose a dedicated android-based bitcoin wallet as there are some risks involved in both spot wallet and cloud-based wallet.
How to Send BTC to Another Wallet?
Transferring a bitcoin from one wallet to another might seem challenging, but it is straightforward, especially with the help of the android device. You need to follow a few easy steps to transfer a bitcoin to another wallet; the first step you need to follow is to select the send option on your bitcoin wallet. Once you click on the send button, the bitcoin wallet will ask the recipient’s wallet address. After inserting the recipient’s wallet address, you need to enter the number of BTC.
Advanced bitcoin wallet allows you to select the amount in fiat currencies and automatically convert it to bitcoin. After performing all these operations, you have to select the send button. Remember that you should double-check the recipient’s wallet address; the only reason is that cryptocurrency transactions cannot be irreversible as there are no government authorities involved in this network.
The above-discussed portion describes whether you can hold bitcoin on an android device and steps to transfer bitcoin from one wallet to another.
