Why a 5-Gallon Water Jug Is Perfect for Home and Office Use
| Updated on November 6, 2024
Five gallon
If there is any drinking water-related issue in your home and office, a 5-gallon water jug is exactly what you need. Ignoring this issue might lead to major problems like various health concerns, dehydration, and whatnot.
Also, even if the water supply at your place is constant but the quality or purification is not good, it can make the situation worse. Hence, it is always advised to go for a 5-gallon water jug solution that is going to help you in need, and also take care of your health.
Carrying out this discussion further, this article is going to share some information on how a water jug can be a blessing in disguise.
Cost-Effectiveness of a 5-Gallon Water Jug
Compared to buying 1-litre water bottles each time, buying water in bulk with a jug is a much better option money-wise. A 5-gallon water jug can easily last more than a day if there are around 5–10 people.
In the USA, the average cost of bottled water is $1.60/bottle. If seen with a broader scope, a jug sits a much better option than buying water bottles for daily use.
Environmentally Friendly Choice
Bottled water is one of the worst things for the environment. According to statistics, “Disposable water bottle waste washes into the ocean, killing 1.1 million marine creatures yearly”. A human being should drink an average of 6 liters of water in a day.
water bottle effect on marine life
With that calculation, it will take around 7-8 plastic bottles that will end up in the trash. Along with that, it will cost you around $12/day. Whereas, a 5-gallon water jug comes as a pretty affordable and viable option for you.
Convenience of Having Fresh Water On-Demand.
Businesses often offer a subscription to these water jugs. This means you can have a jug delivered to your place every day. Even in case you do not need water on a particular day, you can just simply inform them.
This way, you do not need to even step out of your home to get water daily. Just get your jugs delivered to your place.
Space Efficiency
The 5-gallon size of the water jug is quite ample and enough for a number of people. Even in offices, one or two jugs are enough for a day, depending on the size of the firm. Moreover, a jug takes much less space than a crate of water bottles.
Versatility for Different Needs
A 5-gallon water jug is versatile and flexible enough to be used in any setting possible. Whether you need one for your office, home, or kitchen, their service has got you covered.
Not only this, but in sports facilities, complexes, shops, gyms, etc. water jugs will never disappoint you.
Health Benefits of Staying Hydrated
water needed according to weight
Staying hydrating can solely solve various problems for you. With a readily available water service at your fingertips, you can easily fulfill the 4-litre water target per day.
But how will staying hydrated help? Well, it results in various health advantages like improving the digestive system, temperature regulation, circulation, etc. If you are a man, you must drink 13 cups of water each day, and 9 cups for women.
Durability and Longevity
Water jugs are made with sturdy material to ensure that they survive wear and tear during the transportation stage. Also, the jugs need to stay strong so that there are no water leakages. Jugs are also reused over a long period of time, hence, they are durable enough to stay for long.
Some cautiously manufactured jugs even come with UV protection, which keeps the water safe with an extra layer.
Water Dispensers: Hot and Cold Options
Water dispensers come with two options of whether you want hot or cold water. It further facilitates you with the ability to get hot or cold water according to the climate or weather.
Water dispensers average cost around $90-$100. Again, it solely depends on your needs and the number of people at the location.
Safety and Purity of Water Supply
In order to keep their operations running, businesses ensure they continuously provide water with quality and purity. If you go with more expensive services, they even provide mineral water or different ranges that will add extra value to your health along with keeping you hydrated.
Portability and Accessibility
Water jugs can be transported to various destinations easily. As mentioned previously, the jugs are made of durable and recycled plastics, which means it is a pretty versatile as well as eco-friendly option to go for.
The shape of jugs makes them easier to hold and make a strong grip. They can also be refilled and are pretty lightweight.
The Ideal Solution for Home and Office Hydration
Finally, 5-gallon water jugs are a pretty affordable and viable option to go for from every aspect. This article covered almost every aspect in which a water jug is always a better option than buying a new water bottle.
Hence, you also make your first move and start buying water jugs instead of water bottles for your home and offices.
