5 Best Low-Code Platforms For Building Applications In 2025
| Updated on March 19, 2026
Mobile applications have become the most popular thing in the current era. Almost every task can be performed through apps and app development is a good career option.
Building a mobile application is a formidable task especially if you are a beginner and lack coding language. The user experience matters the most and you should be well aware of all the platforms available.
As a novice mobile app developer these platforms help a lot and for them, we have prepared a comprehensive list of low-code platforms. So without wasting much time here are the top 5 low-code platforms that will help you build mobile applications. Also, learn about QXEFV by reading this article.
Choosing the right low-code platform might be tricky with all the options available in the market. We have selected 5 best platforms available in the market to make your task easier.
Newgen
Seamlessly build enterprise-grade applications with the Newgen low-code application development platform. This platform allows you to automate all kinds of tasks with powerful built-in data modeling features.
And make the most of it by pre-built templates and composing a user-friendly and rich application ensuring data integrity as well.  Newgen allows you to speed up the task, streamline application development and build enterprise-level apps with lower coding skills. The fact that it helps you to increase productivity with minimal effort and streamline all deployment processes makes it the top choice in the market.
Softr
Softr is the best for beginners with a simple interface to navigate. Although it lacks advanced customization options, there are a range of templates to choose from. Within a few hours, you’ll be familiar with the entire platform, additionally with the help of AI kickstart your project from scratch.
Streamline all sorts of tasks under just one dashboard which makes multiple tasks to manage efficiently. Put together all the functionality of your app with drag and drop feature making it among the top 5 in the list.
Bubble
With Bubble, you can build almost anything, but it is very much suitable for building prototypes and MVPs. It is widely used among non-code agencies due to its ease of integration and cross-platform compatibility. Due to its active support and customer service, you won’t face any issues working on this platform.
If you face any kind of problem there are a bunch of tutorial videos available. You can also leverage its flexibility feature but if you start with app development it might not be for you because it takes some time to be familiar with the platform.
The only issue is that pricing depends on the workload so if you are seeking some cheap platform where you can perform heavy tasks as well, this one might not be for you.
Appian
Appian might be the choice for those looking to automate process mining and data fabric. The standout feature of this platform is real-time analytics and report and automation that will help you to carry out repetitive tasks.
The only problem with this platform is limited data visualization, but the best part is integrations are pre-built, and API is also available. Create an exceptional user interface with low-code designs.
Nintex
Nintex has all the features that above-mentioned low-code platforms have. Pre-built templates, drag and drop feature, and automation. But the biggest flaw with this platform is that it’s quite expensive and it’s not for complete beginners.
It has a robust automation feature that will help you to manage every organizational task. The mapping feature allows you to give users a centralized view to monitor tasks and make the entire work seamless. With automation, AI gets more ideas and there are more upcoming AI tools that will help the developers to add more comprehensive features.
Best Thing About Low-Code Platforms
Should you really adopt low-code platforms? Well yes because there are a bunch of additional benefits that would boost your productivity. The list of advantages is mentioned below:
  • Drag and drop interface that saves time
  • Range of templates
  • Keep track of task
  • Automates repetitive tasks
  • Robust security to protect your application
  • Cross-platform integration
These were some of the best low-code platforms that you can adopt to seamlessly build and deploy your mobile application. Even having no prior experience in coding it’s very easy to comprehend various complex tasks.
As the demand for high-quality user experience apps continues to grow, these low-code platforms come in handy to stay competitive. These platforms will save you a lot of time and allow you to experience efficient and streamlined app development.
Is no code the future?
As the landscape of technology is developing we are getting a lot of no-code app building platforms. So after a few more decades, we might see this concept integrated in several dimensions.
Is no code platform difficult?
If you want to add complex widgets and tasks then no-code platforms will be tough to operate.
Which is better low code or no code?
In a no-code platform, you can’t add complex tasks. Meanwhile, you can perform complex tasks with low coding platforms.
Who introduced no-code?
James Martin is the brain behind the no-code platform, he pitched the concept back in 1982.
