NT file system, shortly known as NTFS, indeed, is one of the most popular external drive formats, especially for Windows operating systems. In the case of Mac or iOS users, NTFS is not that friendly due to the reason Apple doesn’t have the license to integrate the NT file system with their operating system; hence, it becomes quite troublesome for the Mac users to properly use the external drive that is formatted NTFS.
While Mac users can read the files in the NTFS external drive, it doesn’t allow its users to write the drive seamlessly. To use NTFS for Mac, it becomes necessary to use a third-party application; otherwise, there are a lot of processes to access along with the vulnerability to data loss.
To avoid data loss and read and write effortlessly, it is necessary to choose the right application that actually offers a wide range of options so that you cannot only read and write but also can recover data if necessary. Of all the different applications available out there, iBoysoft NTFS for Mac tool is the best one and widely recommended by IT and data experts owing to its versatile features.
What is NTFS for Mac Software?
As you are already informed that NTFS is a file system that is integrated with Windows and has a lot of features and positive impactful characteristics. Before jumping into the details, if you are a regular Mac user or willing to start using one, you must know that FAT32 is the supported format for external drives to read and write simultaneously.
In such an instance, if you want to use an external drive that has been already formatted to NTFS, you will need to have proper access to the drive to write it. However, if you just want to read the files, you won’t need any extra process to follow.
That means, after inserting your external drive whether it is a pen drive or a portable hard drive, you will be able to look at the files as well as copy those to your Mac to use those files later. On the other hand, if you are looking forward to transferring files from your Mac to an external drive formatted NTFS, you will need to have a third-party application that will allow you to make the drive compatible with your Mac. Then you will be able to start transferring your files to the external drive.
Why do You Need a Third-Party Application?
All the third-party applications that support NTFS for Mac offer several features particularly for writing NTFS drives on Mac. Among all those applications out there, iBoysoft NTFS for Mac is crafted carefully keeping the users’ experience in mind. It allows its users to open, edit, copy, move, or delete files stored on Windows NTFS-formatted USB drives on your Mac. Microsoft NTFS for Mac by iBoysoft is an easy-to-use software that makes this possible.
Of course, you can write your NTFS external drive without any third-party application, but you will be carrying so many burdens on your shoulders. For instance, you will need technical skills to be able to access the drive, meanwhile, there is a chance that you may lose the file. This would make an unwanted scenario, which you don’t want! Why take so much trouble when you can just install iBoysoft NTFS for the Mac application to make the drive smooth and clean.
Using a third-party application makes it easier and convenient to transfer files from Mac to external drives faster, efficiently and most importantly, a large volume of files or data becomes easily transferable which you won’t be able to do if you are using FAT32 formatted external drives.
Just a gentle reminder. If you lose data on Mac there is a possibility that you may not be able to recover it unless you use a data recovery application. Here you also have to use an application for that. Meanwhile, you will go through a lot of stress and trouble. To avoid such unwanted instances, just get iBoysoft NTFS for the Mac application and start transferring files from Mac to external drives in no time.
