Whirlpool has always been a popular name in the world of home appliances. When it comes to washing machines, in particular, Whirlpool has always produced top-notch products. Being such a well-known and reliable brand, the company has always tried to deliver big with its products. Here are 7 impressive features and aspects you can find while buying a Whirlpool washing machine.
1. 6th Sense Technology
One of the biggest assets of Whirlpool is the 6th Sense technology. This technology enables the washing machine to use different sensors to detect the load size. The washing machine then automatically adjusts its operation to make sure that you get the optimum results. Depending on the load size, it makes the necessary wash time, temperature, and water level changes. This not only facilitates the perfect wash but also makes sure that you don’t waste water or electricity. The sensors can also correctly identify low voltage situations. In such cases, they shut down the machine until the voltage fluctuations subside. This helps in protecting the washing machine against any sort of damage. Additionally, the 6th Sense technology can accomplish numerous other important functions. The complete list of the sensors that come with Whirlpool washing machines includes auto distribution, load sensing, auto tub clean, dry tub sensing, water pressure sensing, voltage sensing, and detergent dosage sensing.
2. Spiro Wash Action and 360° Cleaning
This cutting-edge wash motion is designed to give your clothes a thorough wash. The all-new Spiro Wash Action rotates the clothes in a circular motion, which helps them get exposed to the detergent-mixed water. Additionally, the motion also helps in making the water system more dynamic. This gets rid of the dirt, sand, and stains out of your clothes. Furthermore, it has been proven that you get 20% better results with the new Spiro Wash Action from Whirlpool. Furthermore, Whirlpool’s 360° Bloomwash range of washing machines also comes with an efficient impeller with 6 vanes. This results in the clothes rubbing against each other, which removes even the most stubborn stains.
3. Multiple Wash Programs
Limited wash options can often be detrimental to the washing machine’s performance. However, with the variety of wash programs offered by Whirlpool washing machines, you won’t have to worry. Each wash program is specifically designed to serve a particular type of cloth or wash. The White magic series of washing machines offer 12 different wash modes. Some of these include daily, heavy, stain wash, woolens, bedsheets, and whites, among others. All of these modes have different spin speeds that treat the materials accordingly, resulting in a personalized wash.
4. ZPF Technology
In India, water pressure can often prove to be a hindrance while running a fully automatic washing machine, as it depends on the continuous flow of water. To solve this problem, Whirlpool introduced the advanced Zero Pressure Fill or ZPF technology, which ensures that the washtub gets filled even when the water pressure is low. It also speeds up the process, resulting in quick and efficient wash cycles.
5. Express Wash
If you want to get your laundry done in a hurry, Whirlpool’s ‘Express Wash’ option comes to your aid. It reduces the wash time by 30 to 40% while giving you optimum results.
6. Hard Water Wash
Hard water is not known to give the best results when it comes to washing clothes. However, the technologies of Whirlpool are adapted to give perfect results despite the hardness of the water. It treats the clothes gently and preserves their softness.
7. Magic Lint Filter
With washing machines, lint often accumulates in the filters. The lint has to be cleaned manually to prevent any damage. With Whirlpool’s magic lint filter, the lint gets collected and cleaned automatically after every wash. This not only minimizes manual effort but also increases the lifespan of the appliance.
Now that you know what to expect from your Whirlpool washing machine, here are a few Top Loading Washing Machine models you can consider purchasing.
- White magic Royal Genx 7.0 Kg Fully-Automatic Top Loading Washing Machine (Grey, 5 Years Warranty)
- White magic Classic 6.5 Kg GenX Fully Automatic Top Load Washing Machine (Zero Pressure Fill Technology, Grey, 5 Star, 10 Years Warranty)
- White magic Premier 7 Kg GenX Fully Automatic Top Load Washing Machine (Hard Water Wash, Grey, 5 Star, 10 Years Warranty)
- Stainwash Ultra 6.5 Kg Fully Automatic Top Load Washing Machine (In-Built Heater, Grey, 5 Star, 10 Years Warranty)
- 360° Bloomwash Pro 7.5 Kg Fully Automatic Top Load Washing Machine (Hexabloom Impeller, Graphite, 5 Star, 10 Years Warranty)
From washing machines to smartphones — you can now buy anything at no-cost EMIs at the Bajaj Finserv EMI Store. The EMI Store is India’s first-ever platform that deals exclusively with EMIs. The store offers 1 million+ product from the leading global brands. Once you place the order online, the product gets delivered to your doorstep within 24 hours!
Also Read- Factors to Consider While Buying Appliances Online
