It may be difficult for you to choose an ideal laptop considering the variety available in the market. Various brands build laptop models with differences in features and specifications, increasing your confusion. Since it is a costly device, you must be aware of all the important features that you need in a laptop before buying one.
High-end laptops come at a higher price. If you need a feature-rich one, do not worry about the price and purchase the laptop on EMI. It will let you settle the invoice in easy installments. Listed below are some must-check features to look for in a laptop.
Top Features to Check in a Laptop
The following are the most important features you need to look for while picking a model from any of the leading laptop brands:
Display Resolution
You may come across terms like HD (1920×1080), Full HD (1920×1280) or QHD (2560×1440). A display with a higher resolution can contain more pixels per inch (PPI). It can display all the contents on your laptop screen more vividly.
Additionally, you can also check whether a TN panel is available, supporting your screen resolution. It can help you run games smoothly with the presence of high graphics memory. These models can be costly; however, you can own such a laptop on EMI.
Storage Type
Currently, there are two types of storage drives you can get with a laptop, Solid State Drives (SSD) and conventional Hard Disk Drives (HDD). SSDs are much lighter in weight and faster in responsiveness. Windows loading time or accessing files becomes much quicker. However, they are costlier than traditional HDDs.
If the cost is your concern, you can also go with a laptop with both storage types. You will get an SSD with less capacity for storing your operating system and applications only. The HDD will work as the storage device for all other contents.
RAM
The size of RAM significantly influences the overall speed of your system. It lets you run programs faster and smoother. You can experience a quality performance while gaming, photo or video editing, and multitasking.
Due to inadequate RAM capacity, the chances of operational issues, shutdowns, freezing, etc., increase substantially. Hence, you must not ignore the RAM size if long-lasting smooth performance is one of the major concerns. However, models having higher RAM capacity are expensive. You can easily purchase such a laptop on EMI in case of a shortage of funds.
Battery Size
You also need to choose a laptop with a higher battery capacity to ensure that you can use it for longer, even after the power cuts. The ‘mAh’ is the unit to denote this battery capacity.
With an increase in the workload, the battery drains more quickly. So, if you are supposed to run heavy applications on your laptop or engage in long office work, choosing a laptop with a higher battery capacity can be an effective decision.
Further, laptop batteries come with Lithium-ion (Li-ion), Lithium-polymer (Li-Poly), and other chemical compositions. Among all these, Li-ion batteries are more durable, efficient, and popular.
Number of Cores
Laptops may come with dual-core, quad-core, Hexa core, octa-core, or more. With more cores in the processor, a laptop can perform robustly. They are fundamentals for the overall efficiency of a laptop. With a laptop having more cores, you can experience effective temperature management, faster performance, and more power efficiency.
You can witness a high price of a laptop that comes with all the quality features required for efficient performance. Buying these laptops on EMI can significantly help you financially. With it, you can easily afford a power-packed model suited for both work and play.
Nevertheless, you may choose not to buy a laptop on EMI without a credit card. In case you do not have one or want another one, you can go for the Bajaj Finserv EMI card as it comes with several benefits. In addition to buying essential items in installments and with zero down payments, a cardholder can also avail of pre-approved loan offers.
How to Buy a Laptop on EMI using Bajaj Finserv EMI Network Card
Here is a stepwise guideline for buying a laptop with an EMI card:
Step 1: Go to the e-commerce websites that have a partnership with Bajaj Markets
Step 2: Enter your credentials and log in
Step 3: Select a laptop and go for the checkout
Step 4: Choose a credit card as your required mode of payment
Step 5: Pay the bill after selecting your repayment period between 3 and 24 months
Upon completing these straightforward steps, you can purchase a laptop easily with the Bajaj Finserv EMI Card
To conclude, while investing your money in a laptop, you must ensure that it is integrated with all the features required for enhanced performance. If you face a shortage of instant credit, you can go for purchasing such a laptop on EMI.
