Do you power your warehouse forklifts with propane? Are you having propane cylinder storage on-site? If yes, then you need to have complete know-how for their storage to ensure the safety of your gas cylinders.
Propane storage cages are utilized to expand the lifespan of propane tanks and to guard them against any hit or drop, avoiding destructive workplace accidents. Would you like to know about chemical safety methods, especially for your propane tanks? If yes, then you will be glad to know that this article is all about propane safety and storage principles to protect your property, employees, and visitors.
Significance of a Propane Cylinder Cage
A gas cylinder cage is the main component of correct propane storage. Being a dangerous flammable material, propane carries a fatal explosive force, if handled wrongly. By using a gas cylinder cage for storing your propane, a protective structure builds around canisters, avoiding them from puncturing, knocking over, or bumping.
Even the minute hit to a propane gas tank can cause hazardous consequences, such as cylinder leak, collapse, or rupture that can result in a big blast, putting nearby individuals, equipment, inventory, and premises at risk.
OSHA Requirements to Store Propane Cylinder Cages
OSHA (Occupational Safety and Health Administration) has introduced a long list of requirements for propane tanks to ensure their proper handling, storage, and transfer. With respect to the storage of propane cylinders, some essential OSHA storage rules include:
- You can either keep propane cylinders outdoors or indoors, but make sure not to store them near stairways, entryways, high traffic areas, or exists.
- Not storing propane cylinders nearby the combustible or flammable materials.
- Treat empty propane cylinders the same way you treat full ones to ensure safety.
- Place propane cylinders above the ground to facilitate ventilation.
You can fulfill all these requirements by putting propane tanks in gas cylinder cages.
These days, it’s quite easy to find durable, OSHA-compliant gas cylinder cages for proper storage and safety of your gas cylinders. Manufacturers of gas cylinder cages always keep OSHA requirements in mind when manufacturing their products. For instance, manufacturers have incorporated a front door and mesh sides in gas cylinder cages for good ventilation. They have strong roofs to protect cages from falling stuff. Also, they have a lock to restrict the usage and handling of propane tanks. With a lockable latch, only well-trained and authorized employees can access the propane cylinder cages.
The best thing about the gas cylinder cages is that they can also store other chemicals, like nitrogen, acetylene, or carbon dioxide. These gas cylinder cages can store up to 2, 4, 8, or 16 cylinders. They come in fully assembled form, and are thus, ready for use. You will be glad to know that you can also order custom gas cylinder cages. Isn’t it great? Yes, it is! Just make sure to look for compliance with OSHA’s requirements when buying a gas cylinder cage for your workplace. Contact a trustworthy manufacturer to get the best gas cylinder cage.
Also Read: How the Price of Gas has Taken A Toll on Inflation
