If you have limited space in your bathroom, storing your essentials might become a problem. Well, who does not want a bathroom with enough storage space that you can quickly get the things you need, right? In this case, you might want to consider investing in an over the toilet storage space.
By choosing this type of storage option, you can say goodbye to your cramped and cluttered bathroom area. This way, you will find enough storage area for every essential you wanted to place in the bathroom. It could solve all your storage problems in your bathroom area. So, to avoid having these problems, here are some of the best bathroom storage over toilet ideas.
1. Yaheetech 3-Shelf Over-The-Toilet Storage Rack
This type of bathroom storage over toilet is one of the most excellent storage options you might want to add to your bathroom area. The Yaheetech 3-Shelf Over-The-Toilet Storage Rack is available in two primary colors, white and black. It is ideal if you have limited space and have a minimalistic theme bathroom.
Moreover, it is built with rack shelves to give you more storage space and organize your essentials in one place. To add more aesthetics, you can also add a small plant in one of the racks. Well, plants can always give a refreshing look in any area. One good thing about this storage rack is that it does not rust easily and, of course, water-resistant. It is sturdy and durable as each rack can hold 5kg to 9kg of weight.
2. Best Comfort Over-The-Toilet Space Saver
If you are looking to find the right size, the Best Comfort Over-The-Toilet Space Saver could be your perfect choice. It comes in two various sizes, and both can fit as an over the toilet storage. Additionally, it has a spacious shelf that provides enough storage space for your essentials. It also has a cabinet with built-in shelves.
This storage option’s design is best described as durable, delicately decorative, highly functional, spacious, and traditional. So, it is no doubt that it can significantly add to your bathroom area’s overall aesthetics. This storage rack is also coated with a particular paint, which makes it highly resistant to rust and water.
3. Over-The-Toilet Bathroom Spacesaver by Zenna Home
The Zenna Home Over-The-Toilet Bathroom Space Saver comes in two different styles. You can use this as a space saver or a wall shelf. This storage option may be lightweight, but it’s one of the most durable storage racks you can choose for your bathroom. The frame is made of metal, while the shelves are made of solid wood.
With this over the toilet storage option, you can easily keep your skin, body, and hair essentials without any problem. Moreover, it is easy to assemble and has great value for money. This modern yet traditional look of this storage rack will surely complement any bathroom themes.
4. Tier Over The Toilet Storage Rack by Tangkula
The Tangkula 3-Tier Over The Toilet Storage Rack to organize your bathroom is made with high-quality iron that is anti-corrosive. It is also highly-durable and can hold up to 17 lbs. of items for a long time. In addition to that, it has three shelves that are spacious to give you enough storage space to keep your essentials in one place.
An addition of a small plant or decorative candle could significantly add to your bathroom area’s overall aesthetics. This storage rack is easy to assemble and maintain, so you don’t need to worry about it.
5. Over The Toilet Wall Cabinet by RiverRidge Somerset
If you’re looking for an over the toilet storage option that quickly hides your essentials, then this could be the perfect choice for you. The RiverRidge Somerset Collection Over The Toilet Wall Cabinet can double as a bathroom cart or a wall cabinet. It has one shelf, but that single shelf could provide enough storage space for your items.
The cabinet has two shelves inside, so if you have essentials that you barely use, that could be a great space to keep them. One of the shelves can be adjusted to your preferred measurement, and one is already fixed. But, it doesn’t matter because as long as you have an area to keep your item. The design can be easily described as contemporary or modern as it has a touch of gray and white colors.
6. Two Doors Storage Cabinet Tower
One of the ideal storage racks for your bathroom is the Double Door Storage Cabinet Tower. It’s easy to maintain and highly durable. Moreover, it has a wide shelf and clear windows that allow you to identify the items that are in store. You can also find two wide shelves on the cabinet to give you more storage space.
Takeaway
There are a lot of over the toilet storage racks you can find in the market today. Each of them has various designs, sizes, colors, and materials used. So, if you’re looking for a reliable and sturdy storage rack for your bathroom, you might want to consider choosing one from the list.
