Table of Contents
Data analytics is a booming field with high demand in both business and government sectors. The programming languages such as R and Python are widely used for this domain due to their powerful libraries for data visualization and creating informative plots for scientific experiments.
The increasing importance of this field has led to an increase in demand for qualified professionals with these skills. Data analysis courses are designed to teach students the fundamental skills they need to become effective analysts and build foundational knowledge like how to analyze information and identify patterns, and how to create reports that communicate findings clearly and compellingly.
Data analysis is a foundational skill in any data-driven business. Around 52% of the companies all over the world already are trying to gain the most from data analysis. Therefore, an aspiring data analyst and data scientist should be well-acquainted with the best data analysis techniques. So here is a list of some of the data analysis techniques so you can get a glimpse:
Regression Analysis
Regression analysis is primarily conducted to estimate and find out the relation between a set of dependent variables (which is the variable that is to be measured) and multiple independent variables (that affect the dependent variable). The purpose is to study how the independent variables can impact the dependent variable. This process leads to the identification of different trends and patterns.
Regression analysis is especially useful to make predictions and learn about future trends. One such instance where this is especially useful is the E-commerce industry where correlations are to be established between different variables. For instance, the relation between the marketing budget and the revenue earned as a result of pursuing these marketing campaigns. A positive correlation would be established if it is found that money spent on marketing is directly proportional to the sales revenue.
However, if both are found to be inversely proportional then the marketing campaign is deemed to be ineffective. However, the one major limitation of regression analysis is that while it does tell you if there is a relationship between the variables or not, it will not give you an idea about the cause and effect of such a relationship. Hence there is an absence of definitive conclusions. There are many different types of regression analysis depending on the type of data whether it is continuous or categorical.
Monte Carlo Simulation
When you make decisions or take action it can lead to different kinds of outcomes. In such cases, it is better to calculate all the potential risks and rewards of different outcomes. The Monte Carlo method creates models of all possible outcomes and their respective probability distributions. The probability is assigned based on the likeliness or realization of each outcome. This technique is used primarily by data analysts while conducting risk analysis for forecasting future events and taking decisions accordingly. This is one of the most popular techniques for measuring the effect of unpredictable variables on different output variables and for conducting risk analysis.
Factor Analysis
This method helps in reducing a large number of variables to a lesser number of factors. This condensation of the data set simplifies the analysis process and makes it easier to find the desired results. Factor analysis is based on the premise that different variables are correlated with each other due to an underlying construct. This is extremely helpful when you want to minimize the volume of data sets to identify the patterns.
One approach towards factor analysis begins with collecting data based on customer satisfaction survey forms. Once the survey is completed instead of looking at each individual response, the responses are clustered into factors. After this, a correlation is found which is referred to as covariance. Hence this technique is ideal to measure imponderable aspects like happiness, customer loyalty, or fitness.
Cohort analysis
This is a part of behavioral analytics and it works by dividing the data set into groups for analysis. This division into groups or cohorts is done based on similar characteristics shown by different data points within a particular time frame. With the help of this analysis, you can divide your customers or userbase into different groups and analyze their behavior over some time.
Hence, instead of looking at isolated snapshots, you get to capture the journey of a customer and the experiences over the customer lifecycle. This will tell you a lot about their behavior at different points in time. For instance, the first time they visited your online store or signed up to your email mailing list, or made a purchase or return. This dynamic analysis method gives you valuable insights and allows you to learn how to satisfy your customer even better. It also allows you to tailor your services according to your customers’ requirements and wishes.
Additionally, you can run campaigns like discount campaigns or add new features to the website based on your customers’ responses. Every time you get a new group of customers you can study their patterns and offer them discounts or other offers based on the results of cohort analysis. This data analysis technique is widely used by companies that are trying to optimize their offerings to provide a personalized experience to their customers
Cluster Analysis
This exploratory technique is used to identify unique structures inside a data set. The objective of cluster analysis is to make clusters of different data points such that they are internally homogeneous but externally heterogeneous. This means that within a cluster the data points are similar however the data points between two different clusters are dissimilar. This technique is especially helpful in identifying the distribution of data within a data set and it is often used as a pre-processing step for other algorithms.
Cluster analysis is a very popular aspect of machine learning and hence is widely used in many real-world applications. For instance, in marketing, it is used to divide a large customer base into distinct segments. This allows the companies to adopt a more targeted approach in their communications and advertisements.
Similarly, insurance companies can conduct cluster analysis to find out why certain geographical regions have a higher number of insurance claims. It can also help in geology to predict earthquakes. While cluster analysis can reveal structures within the data set it won’t necessarily help you find out the reasons for the existence of these structures. However, it is a good starting point to understand your data and gain insights for further analysis.
