As technology is upgrading itself, people’s lifestyle has undergone a drastic change. These days everything can be controlled with the appropriate use of technology. Over the years’, keypad mobile phones have evolved into smartphones, TV sets that were not so smart are now known as Smart TV. Now, there is no more struggle to look for the remote to change the channel, just talk to your TV. Even other electronic gadgets have turned so smart; all thanks to the smart home mobile development that has made everything easier.
A home automation system lets you control everything related to your home; the mobile application solutions have turned the smartphones into a remote; if you are looking for the apps to make your life easier, in this guide, you will find the top recommendations, but before that let’s know the ways in which these smart home apps and devices help.
The Top Benefits and Uses of Smart Home Apps
Apart from being a way to keep up with the latest technology or an opportunity to show off, smart home automation has several other benefits and uses as follows:
1. Improved Security
Incorporating security and surveillance features in your smart home network work as a plus point for your home security. Get security alerts on your device and monitor activities going in your house in real-time whether you are physically present or not.
2. Convenient
Isn’t it convenient to manage all your home devices from one place? That’s what these smart home apps let you do. Connecting all your technical devices at home to one network is the best step you can take towards home management.
3. Time-Saving
Apart from managing your home, it also saves a lot of time. It is possible to forget one thing or the other when you have a lot to do; with smart home automation, there is nothing you will forget, or even if you do, you can control it from your smartphone.
4. Better Energy Efficiency
You can have complete control over all your home electronics with smart home automation and due to that, you will be able to save a lot of energy such as by using the correct temperature settings, setting lights to turn on and off automatically, and what not.
After knowing the benefits of smart home apps, you must be curious to know what apps you can use for better home management. For the best smart home experience, you can check out the following top IoT applications for convenient and comfortable living.
Top Smart Home Apps for a Smart Home and Better Life
Here are the top recommendations for the best smart home apps:
1. Amazon’s Alexa
Amazon’s Alexa is the first step to smart-home automation systems; the Alexa app is known to control all the Alexa devices as well as some other smart home devices as well. With this app, you can set up your Amazon-enabled devices, create a shopping list, or listen to music.
2. Samsung Smart Home
Another top smart home app that lets users easily connect with Samsung home appliances, such as refrigerator, washer, air conditioner, oven, vacuum through your smartphones. The app even supports iOS 8.0 and above. So, controlling all the devices is just a matter of a few minutes.
3. Apple HomeKit
Apple HomeKit is a dedicated app for Apple users who can use it to easily control their home using iPhone, iPad, Apple Watch, HomePod, Apple TV, and Mac and maintain the security of their homes. Ask Siri to do the things for you and manage your home with one command.
4. Google Assistant
Google is the answer to all our problems; similarly, Google Assistant is there to keep all your things organized at home. You can ask the virtual assistant questions, tell it to do things, or get help whenever you want. Google Assistant comes in handy when you don’t want to type to give a command.
5. Philips Hue
You can manage your home lighting system with the Philips Hue app. With this app, you can control the functioning of lights in a single room, set automatic light routines or you can also sync your lights as per the thing you are doing such as music, films, or games.
Wrap Up
With constant changes in technology, everything is getting smarter. To keep up with the changes and keep your home secure and under your control, nothing could be better than taking the help of smart home automation apps.With so many smart home automation systems available in the market, it can be quite difficult to select one and the best for you among all the top IoT apps to make your home smart. Just go through the features provided by each of the apps and select what is helpful in making your home smarter and securer.
