Imagine hosting important guests in your home, and suddenly, they find bed bugs stuck to their clothes from your chair? They might think you’re untidy for living in such a home. To avoid this kind of awkward situation, you should try to keep bedbugs away from your home. A1 Bed Bug Exterminator Scarborough | pestandbedbugkillersofscarborough.ca can help you do that. You can also follow the simple tips below to make your home bedbugs free:
Inspect Second-Hand Furniture Before Taking Them into Your Home
One of the easiest ways to have a bedbug infestation in your home is by bringing in furniture that has bed bugs in them. Furniture like chairs and tables are familiar hidden places for bedbugs. Therefore, if you purchase second-hand furniture, you may be unlucky to bring home bed bugs with it. What you need to do is to ensure that a proper inspection is done when you purchase second-hand furniture. You should check every corner of the furniture and ensure that there’s no single bedbug hidden in them. If unfortunately, you found a bedbug in the furniture you’re about to purchase, you may want to reconsider your options and go for another furniture, or better still, go for a new one if you can afford it. You can also treat the furniture to kill the bedbugs.
Inspect Where You Stay When You Are Away From Home
You may desire to get a roof over your head when you’re away from your home. If you lodge in a hotel, for instance, you should do a thorough checking of your hotel room before you unbox your belongings. The moment you open your clothes and other belongings in a bedbug-infested place, the bedbugs are likely going to get into your clothing and your other belongings. This means when you finally take your leave from the hotel, you’ll be carrying bed bugs with you and eventually take them to your house like that. It is, therefore, essential to check your hotel room thoroughly before you unbox your personal belongings. You should check the bedsheets, the mattress, as well as the furniture in the room. If you find bedbugs there, you should leave immediately for some other place.
Be Cautious Of The Dry Cleaner You Patronize
Another easy way to bring in bed bugs into your home is through an infected cloth. If you patronize a Dry cleaner with bed bugs infested office, it is most likely that you’ll get back your clothes with bed bugs in them. This means you’ll be transferring bed bugs into your house through those clothes. You can avoid this by knowing more about the Dry cleaner you intend to get work done from. You can meet with anyone whom you know already deals with such dry cleaner and ask questions about their experience dealing with them. Ask if they ever found bedbugs in their clothes after being received from the dry cleaner. If you can’t find anyone to help with your findings, it’s still okay. You have to be extra careful while they gain your trust. Also, make them aware that you do check for bed bugs. By doing this, the Dry cleaner realizes that you’re cautious. Hence, they’ll want to take extra precautions to ensure that your clothes are bedbugs free before delivering them to you.
Check Your Pets For Bedbugs
Pets like dogs are the primary carriers of bed bugs. This is, especially, not good for anyone who allows their pets into their rooms. The safest thing to do is to prevent your pets from leaving the house. This is important especially if you suspect that there are other pets in your surrounding that have bed bugs on them, or there are homes in your surrounding with bed bugs infestation. It would help if you only allowed your dog to stay in your compound. If your dog moves around the neighborhood and you don’t have a barricade to keep them in your compound, you need to always check them to ensure they have no bedbugs on them. The moment you find out bedbugs have infected your pets; you should not allow them to get into your rooms. It would be best if you subjected them to a chemical bath. That’s not all. You will also need to check their bed and where they sleep for possible bed bugs infestation. Wash their beds with the highest heat and dry them appropriately.
If you can follow these simple tips, your home should be bedbugs free.
Also read – Tips to Choose Kitchen & Home Appliances
