Today, plagiarism is a common issue. Students don’t want to research and write original content anymore. They want a quick and easy way to complete their content. And what better way than copying someone else’s work.
Most of the time, college students cannot sustain the pressure of work and project deadlines. So duplicating someone else works looks like a brilliant solution. But this should not be the case. It’s wrong to copy someone else’s work without crediting him or her. Furthermore, if a college student gets caught with plagiarized work, he might have to face severe consequences.
So how does a student get caught? Well, through plagiarism detection software. The teacher can run various class assignments to check for plagiarism. But how do plagiarism checkers work? What’s the technology behind it? To learn more, continue reading.
How Plagiarism Checker Works?
The way plagiarism checkers work can seem like magic -you upload a document, then you receive back a report of plagiarized sections. But it’s not magic – there’s an explanation on how they work.
Once you’ve uploaded or pasted your document onto the plagiarism software, a plagiarism detection algorithm gets into action. It breaks down the content into smaller chunks of phrases and searches for similarity in the search engine. Once it encounters similar content, it marks the plagiarized words.
Writing is inevitable in school; Most college students rely more on online information to complete their lesson writing assignments. As a result, their document can contain plagiarized content. To check if you’ve duplicated someone else’s work, you can use plagiarism checker online at https://gradesfixer.com/plagiarism-checker/ for fast and accurate results. What’s even better, you don’t have to pay anything. You can check your coursework and lesson assignments for free.
Coursework and assignments make up 45% of your overall education grades. Hence, it’s wise to ensure you deliver quality and plagiarism-free content if you want to secure higher marks. That said, here’s a list of technologies behind plagiarism checking software.
What Technologies are Used for These Tools?
1. Artificial Intelligence (AI)
Artificial Intelligence dominates most sectors in today’s world, from communications to security. In plagiarism checker software, AI works to detect content that might share similarities to original and published texts. Irrespective of how paraphrased or rearranged a content is, checkers using AI can determine copied or duplicated content across several platforms.
2. Machine Learning
AI and Machine language complement each other in various ways. When you run a document on plagiarism checker software, AI detects the plagiarism, and machine learning reads your actions and adjusts its predictive model to offer you correct scan reports in the future. In terms of plagiarism, machine learning finds potentially plagiarized content by drawing information from a database.
3. Natural Language Processing (NLP)
The unique writing style of each individual might affect the analysis of plagiarism detection software. That’s where NLP comes in. It’s a technology that helps the computer to understand how humans speak. Therefore, it can design a better translation process, summarization, sentimental analysis, etc.
In plagiarism checking software, NLP reads the way individuals write- be it an academic, professional, social or natural. The plagiarism system cross-reference text and sentences, ensuring it’s not copied or duplicated.
4. Stylometry
Stylometry is a statistical approach to the analysis of unique writing styles. A plagiarism tool that uses stylometry will determine if the text is a product of the same author or it’s another writer trying to copy the author’s style.
The software achieves this by comparing different text segments and passages of the documents. Besides detecting plagiarism, stylometry helps to confirm the authorship of texts to prevent conflicts.
5. Database
There are over 60 trillion pages online stored in databases. A plagiarism checker can go through all the information stored in databases and compare them to your document content. And if the report has no case of plagiarism, then your article is unique and original.
6. Approximate String Matching
Approximate string matching is an approach used to identify matching patterns. You could encounter this technique in dictionaries and search engines when searching for the correct result if you misspelled a word. Though mostly used for checking spellings, some plagiarism checker tools use it to identify similarities in text too.
Plagiarism is a vital element in every kind of writing. Always run your documents through plagiarism detection tools to avoid publishing or submitting plagiarized work. Also, take measures such as mentioning references and understanding the content instead of copying and pasting.
Each of the technologies behind plagiarism software will help you detect plagiarized content to some extent. Thank you for your time!
