Whenever you learn about hosting, you might cross across two similar-sounding terms, i.e., VPN and VPS. Though both these terms seem to be pretty similar they are entirely different from each other. Yes, you read it correctly!! VPN and VPS are two different terms that have nothing in common except one or two. So, if you are confused regarding how both these hosting differ and which one is better for you, then we have got you covered in this article where you will get to know everything about VPN Vs VPS. As a bonus tip, we will also uncover the best option to get cheap Windows VPS at the end!
Let’s start then!
What Is VPN?
VPN stands for Virtual Private Network. It creates a secure and private network that extends across the entire network connection. The VPN web hosting services allow you to remain anonymous online while protecting your data that passes over the online network.
When you use a VPN, any data that you transmit over the internet network goes straightaway to the VPN server from your Internet Service Provider. Later, the VPN connects to the internet for you. This entire process diminishes a handful of security risks that you will run while being online. All your data is encrypted under VPN hosting services, so if your data is anyhow intercepted, no one will be able to paraphrase your data.
When Should You Use VPN Hosting?
Have a look at the situations below to get an answer to when and why to use VPN hosting services!
- To get around and access blocked content online
- To get secure network and data connections
- To remain anonymous online
- To switch from unsecured Wi-Fi networks
Pros and Cons of VPN Hosting
Below-mentioned are the pros and cons of using VPN Hosting!
Pros:
- It keeps you safe and secure online
- With VPN, you can easily access geo-restricted content
- It encrypts your data before sending it over the network
- VPN protects your data
Cons:
- A VPN connection can drop frequently
- Security issues can arise sometimes
- You may experience slower internet connectivity
What Is VPS?
VPS stands for Virtual Private Server. It is just a computer system that you generally use at your home. The VPS can run any kind of software just like your PC. It is basically used as a primary solution to host websites and offers a reliable web hosting solution to all users. A VPS is hosted online, and it runs a dedicated operating system that can easily be accessed through a paid subscription.
Under VPS web hosting services, the central server is divided or fragmented into multiple virtual compartments, each of which works independently from the rest of the compartments. Each of these units or compartments acts like a private server for one specific end-user.
When Should You Use VPS Hosting?
Below mentioned are the situations that will call for the need for VPS hosting services!
- You want flexible server resources
- You want a custom server setup
- You have a higher volume of traffic on your website
- You need excellent performance and quick speed
Pros and Cons of VPS Hosting
Below-mentioned are the pros and cons of using VPS Hosting!
Pros:
- Greater control over the server
- Easy to scale your server
- It is cost-effective
- Greater server customization options are available
Cons:
- You can fall into resource allocation problems
- It is comparatively more expensive
As you have gone through the detailed description of VPN and VPS web hosting services, now it’s time to get an insight into a quick overview of VPN Vs VPS.
VPN Vs VPS: Highlights
If we talk about VPN, then it’s a user-oriented tool that allows the users to browse the web securely and safely by being anonymous, while a VPS hosting service allows the user to host the website on a virtual server environment. However, the only thing that is common between VPN and VPS web hosting services is the virtualization aspect of each of the services.
Both VPN and VPS serve entirely different requirements, but you can rely upon both services as a user. For Instance, if you have got a high traffic volume on your website, then you can use VPS web hosting services to host your website. In contrast, you can use VPN software to access the internet to manage your website and to secure the data that you intend to send over the internet network.
This is how VPN and VPS differ from each other! Now, let’s learn about the best VPS service provider on the internet who serves the best-in-class cheap windows VPS services to all its clients.
Router Hosting: #1 VPS Hosting Service Provider
Router Hosting is the No. 1 VPS hosting service provider online. The company was initially founded in 2008, and since then, it is continuously delivering excellent services to its entire client base globally. Router Hosting has made hosting services much more accessible and affordable than ever before. They mainly focus on Cloud VPS and Virtual Private Servers services. With years of experience, they have successfully integrated an automated platform that helps users to save money and time.
Why Choose Router Hosting?
- Guaranteed uptime
- Supportive customer support team
- 7 days money-back guarantee
- No failure, No outages
- Reliable connectivity
- Dedicated Resources
- Quickest Hardware
- 12 years of hosting experience
Top Router Hosting Services
Amongst all the VPS services at Router Hosting, the top 2 VPS services involve:
Windows 10 VPS Services
At Router Hosting, you can buy Windows VPS with Bitcoin. Yes!! Router Hosting accepts Bitcoin payments to offer you the best VPS windows 10hosting services. Best of all, they provide a cheap Windows VPS service plan with free Windows of any version that you want. All the Windows VPS services of Router Hosting are equipped with a completely automated Virtualizor Control Panel that will let you control everything with your VPS server.
RDP VPS Services
With Router Hosting RDP VPS Services, you can manage your VPS resources flawlessly. The RDP VPS hosting services of Router Hosting come in any color of Windows that you want. By buying their cheap RDP VPS services, you can do reconfiguration instantly and can have complete access to your virtual servers. All this will make it easy for you to connect and manage your remote desktop. They will offer you the minimum hardware required for a reliable RDP connection and server performance at a pocket-friendly price. Router Hosting’s VPS machines with dedicated, excellent quality resources bring you the right kind of reliability and performance that you want.
Hope you have now understood how VPN and VPS are different from each other! You can now decide which hosting is better for you, and then you can move forward to buy it from the best hosting service provider online. But if you are choosing to buy VPS hosting, then Router Hosting will be a perfect option for you because it offers cheap Windows VPS options and allows you to buy Windows VPS with Bitcoin.
