Painting a commercial property is entirely different from painting a residential building. Each task comes with its own set of skills, requirements, and tools. However, many people often confuse these two tasks. According to them, painting is painting, regardless of where or what you paint. Well, that thought isn’t true. Surepaint serving all of Brisbane and wants to help you understand the significant differences between these two types of painting. Let’s dive in.
The Project Size
The scope of each painting project is different. Residential painting services paint your home interior and exterior. Each part is well-prepped before the painting begins. The residential painting projects are done in houses, condominiums, townhouses, and other living spaces. Homeowners can either paint the entire home, a few interior spaces, or their home’s exterior only for residential painting.
For commercial painting, painters apply a fresh coat of paint to apartments, office buildings, hospitals, schools, and manufacturing facilities. With the building being relatively more extensive than houses, commercial painting projects are also larger than residential.
Number of Painters Involved
Painting large commercial buildings like office buildings will require more painters compared to painting a home. The more the painters, the easier it becomes for the company to meet deadlines and cover every area of the building. For a painting contractor to complete a commercial painting project on time, they have to employ more painters.
The project size for residential painting is relatively small, and it doesn’t require as many people to complete the project. Painting contractors will have a few people finishing the project, depending on the requirements of the project. For example, if the homeowner wants a couple of bedrooms to be repainted, the contractor will only send two or three painters.
Equipment and Material
Since residential painting focuses only on residential projects, the equipment and materials used are not too different from the supplies you can purchase. Some materials the painters will bring for residential projects include painting trays, paint brushes, rollers, drop cloths, stepladders, and cleaning materials. Also, the type of paint they use has to match your home’s architecture and décor.
To ensure that all the colors match your home, painters will use different paints for residential projects. Their base’s paint is either latex-based paints, water-based paints, or oil-based paints. The painters also use different paints to achieve glossiness or sheen at the end. The paint they choose will depend on the outcome of the other coats of paint.
The equipment used for commercial painting is a little complex as the painters handle different surfaces. Some equipment they use includes sandblasters, pressure washers, aerial lifts, paint sprayers, and scaffolding. They also use industrial grade and commercial paints, tints, primers, and other coatings.
The Services they Provide
Compared to residential painting, commercial painting offers additional services. Some of these services include epoxy coatings, special surface preparation, industrial coating, and painting. However, the services commercial painting contractors offer to depend on the contractor.
For residential painting services, you can expect contractors to include in-home painting. Other services they offer include cabinet painting, drywall and plaster repair, wallpaper hanging, and removal.
Amount of Paint
Commercial painting requires a lot of paint because of the large spaces that need painting. So contractors use different equipment for this type of project. However, this doesn’t mean residential painting projects will not require a large amount of paint, as the home’s surface area may be relatively larger than predicted.
Experience
Commercial painters have more experience compared to residential painters. It takes skill, experience, and endurance to finish painting an entire warehouse successfully. However, this doesn’t mean that residential painters don’t have knowledge or skill; they do. They know how to communicate and accomplish the vision of homeowners.
They are also knowledgeable on how to protect your valuables and future during the painting process. With this skill, any homeowner is guaranteed not only outstanding results; but also a unique experience.
Schedule
Commercial painters work more with the client’s schedule. This might mean pulling all-nighters to ensure that your business continues to operate during the day. For residential painters, their schedule is within regular business hours and days. Usually, they work eight hours a day. But customers can also have a target schedule for them to follow.
If you’re thinking of having your business or home painted, look for a painting contractor that offers both services. Such a contractor is skilled in both areas.
