General » Converting Regular Bikes to e-Bikes-Can It be A Business Venture
Posted on May 4, 2020 | by GetAssist.net
Cycling is one childhood memory that continues through most of our adulthood too. Apart from being one of the best natural workouts, it is also an environmentally healthy alternative to fuel vehicles.
A bicycle is cheap, affordable, easy to maintain, and barely leaves any carbon footprint. No tension of insurance or endless hours waiting in traffic. However, in case you suffer from any limbic issue, pedaling a cycle and maneuvering it can be stressful.
Especially challenging to ride uphill or on rough terrain, bicycles become more a hindrance than help. An electric bike is an excellent alternative in such a scenario.
Electric bikes are easy to ride, barely need any pressure on the pedals, and certainly with better navigational capabilities.
The only negative aspect of an e-bike is the cost. Relatively expensive, e-bikes are not viable options for most. Even if you go for the best electric bike under 1000 dollars, you won’t get all the options you desire.
Keeping the affordability aside, the unavailability has also become a reason for the lack of e-bikes around. To compensate for the unavailability and the cost, a new strategy is being experimented on.
Converting a regular bike into an electric bike is one of the most common DIY projects currently.
Converting traditional bike into an electric bike
These days complete conversion kits are readily available in the market that makes it easy to modify the bike.
The conversion kit offers a comprehensive guide book to assist one through each step of the process along with the necessities.
Generally, conversion kits contain
  1. Single wall alloy rims
  2. Lithium-ion battery with 7.8Ah and 10.4Ah capacities normally.
  3. A display panel that is basic or multifunctional
  4. Full twist throttles
  5. TORQ motor with a 250-watt minimum capacity
Process to change bicycle to electric bike
The entire process of the transition of an uncomplicated bicycle into an electric bike takes a few minutes barely.
  1. First and foremost, it is essential to change the front wheel of the bike from a standard wheel into the electric mode compatible. The conversion kits generally come with an alloy electric front wheel that is universally compatible with all bikes.
  2. Once the wheel is secured in place, attach the battery and motor to the front wheel.
  3. The next step involves placing the throttle. Throttles are ideally situated on the inner aspect of the handlebar. It is best to unscrew the handle cover, fix the throttle in place, and then replace the cover again.
  4. Once the throttle is in place, it is now time to connect the cable from the accelerator to the battery.
The bike is ready for use now. Generally, a single full charge battery of a 250-watt motor can cover approximately 30 miles of distance at 15 miles/hr speed.
Additional accessories like GPS tracker, navigational units, and LED lights can also be attached. However, these extra fittings are not always an inclusion in a conversion kit and need to be purchased separately.
Based on the requirement, a converted electric bike can generally have three or more usage modes. These are
  1. General bike mode- For day to day life regular cycling. None of the upgraded parts are in use. The bike normally moves with pedal assistance like a regular bike.
  2. Pedal-assist mode– Suitable for rough and uphill terrain. The motor activates the pedal movement function. This allows less strain while pedaling with higher speed motion.
  3. Full electric mode– With the throttle in full work mode, there is not much for you to do except relax and let the bike move on its own.
Can conversions of bicycles into e-bikes be considered as a business venture?
DIY projects do not always guarantee success. It is a trial and error process based on the theoretical knowledge and ideas applied together. Additionally, the conversion kits and other necessary inclusions are often not very easy to buy or find.
Bicycle conversions are a much more affordable option than the branded and authentic electric bikes available. Moreover, the idea of reusing the old traditional bicycles instead of dumping it for a more sophisticated newer version is a much more likable idea.
If someone with professional knowledge and expert skills takes up the project of converting old bicycles into electric bikes, it is bound to be more polished and much more secured for use.
Considering it as a business venture will be profitable. A faster alternative without being strenuous on the pocket is always a lovable option.
Since the conversion of bicycles into electric bikes requires a few critical elements and sound knowledge, the result is not going to be an expense that burns a hole through the pocket of the customers.
Moreover, there will be ample profit margin left even after selling it at a minimal viable price.
Electric bikes are here to stay. A faster and better upgrade to the traditional bicycle, converted e-bikes are affordable and durable enough to use just like a standard brand name e-bikes.
Tweet
Share
Pin
Share
0 Shares
  • Type Your Question
  • How to Get the Best Kraft packaging
    Choose Kraft Packaging from Best Listed Company
  • Benefits of Intelligrated Conveyor Currently
    Who Benefits From Intelligrated Conveyor Currently
  • Find a Good Printing Service
    How to Find Good Printing Services in Singapore?
  • Best Chainsaw Safety Training Online
    How to Get the Best Online Chainsaw Safety Course for Business?
  • Online Course for Transportation of Dangerous Goods
    Transportation of Dangerous Goods Training Directly to Your Home Online
  • Mati Kochavi & Bill Clinton Interview
    Mati Kochavi & Bill Clinton interview
  • How do i teach my child voice lessons
    How Do I Teach My Child Voice Lessons?
  • How to Recycle Old Mobile Devices
    Recycle Your Mobile Phone to Curb e-Waste
  • Subscribe to Our Newsletter
    • Blog
    Mail Id: info@getassist.net
