How to » Social Media » Instagram » A Guide to Block and Unblock Someone on Instagram and the Aftermath
Posted on October 30, 2020 | by Shinely Ainsworth
An online platform where 80 million photos are shared on a normal day and 3.5 billion likes; Yes, I am talking about Instagram, one of the top social media websites. In 2018, it crossed the 1 billion mark of monthly active users and every year users are only increasing. Instagram is a place where you can get a sneak peek into your favorite celebrities’ life, interact with your friends, family, relatives, and so on. Just like Facebook, Instagram is also full of spammers, stalkers, and other bad guys, and whenever we encounter someone of that sort, only one thought crosses our minds i.e. how to block this annoying person on Instagram.
Blocking someone on Instagram is easy and will not consume hours; this article will also talk about how to unblock someone if blocked mistakenly or what happens if you block someone on Instagram, do they get to know about it, and similar other concerns.
So let’s start
Table of Contents
Possible Reasons to Block Someone on Instagram
Steps to Block Someone on Instagram
Steps to Unblock Someone on Instagram
What Happens After Blocking Someone on Instagram?
Summary
Blocking someone means you are not interested in seeing that person’s profile or you no longer want to interact with them. I know, you are well aware of why you want to block a particular person, but here are some common reasons due to which people want to block someone.
Is your reason is there in the list?
  1. An unwanted friendship
  2. Someone is talking inappropriate things
  3. Your friend unfollowed you
  4. Spam accounts
  5. Annoying users
No matter what is the reason; go ahead and block that person using the tips mentioned ahead. Also, if you are thinking about how to block a person on Instagram without them knowing, stay assured as Instagram doesn’t send any notification to the person when you block them.
Now, to block someone on Instagram, you have to follow the same steps as listed below:
  1. Go to your Instagram app on your mobile and then tap the ‘Search’ icon at the bottom of the screen.
  1. Type the name of the account that you want to block and select the Instagram account from the search results. (For reference, I am going to show how you can block Facebook).
  1. Now, tap the menu icon (three horizontal lines) at the top-right corner.
  1. You will get a few options on the screen; from the list tap ‘Block’
  1. Tap ‘Block’ again to confirm.
That’s how you can simply block someone on Instagram who blocked you.
In case, you have mistakenly blocked someone on Instagram, use the steps given below to unblock them. Two methods are there using which you can unblock someone:
First Method:
  1. Using the search icon, look for the person’s profile you want to unblock;
  1. From the options that you see, press the ‘Unblock’ to unblock them.
  1. Again press ‘Unblock’ for confirmation
Second Method:
  1. For the second method, go to your Instagram profile and tap the menu icon (three horizontal lines) at the top-right corner.
  1. Tap ‘Settings’ at the bottom of the screen
  1. Tap ‘Privacy’ from the list of options available to you.
  1. In the ‘Connections’ section, tap ‘Blocked accounts’.
  1. You will see the list of all accounts that you have blocked, tap ‘Unblock’ for the one you want to remove from the list.
  1. Again tap ‘Unblock’ to confirm and that’s it.
That’s how you can unblock someone on Instagram that blocked you and all the steps are updated as per the latest 2020 version.
However, remember that you will need to follow the person again as blocking them will remove you from their followers’ list.
I know you were here to know if you can block someone on Instagram or how to do that. Using the steps mentioned above, you can permanently block someone on Instagram but that’s not just it. There are some questions that you must know the answer to such as:
  1. What happens when you block someone on Instagram?
  2. Can you see someone’s profile after you have blocked them on Instagram?
  3. What happens when your profile is public and you block someone on Instagram?
So here are the answers:
If you are worried that the user will find out you have blocked them, so first of all they will not receive a notification on Instagram that they have been blocked by you. But when they will notice that they are not able to see any of your content, they may realize this. But this will happen in the case of a private account; the blocked person will not be able to see your pictures, videos, and also the comments you have given on other users’ posts. The likes or comments you have given on the blocked person’s posts will automatically be removed and from that time onwards, they will not be able to tag you in pictures, comments, or direct message you.
In the case of a public account, the person you have blocked can see your likes or comments on other user’s posts. However, they will see no posts, followers, or people you are following.
Also, if you want to know if someone has blocked you, you need to check for the same things as mentioned earlier. In case, someone has blocked you, there is no way you contact them on Instagram.
Summary
So if you want to block someone on Instagram, you can do that by visiting their profile and from the menu, click on ‘Block’. Furthermore, if you want to unblock that person, you will see the ‘Unblock’ option on visiting the person’s Instagram profile. You can also unblock the person from the settings and in the list of the blocked accounts, simply tap Unblock for the person you want to remove from there. It is that much simple to block or unblock someone on Instagram.
Tweet
Share
Pin1
Share
1 Shares
  • Type Your Question
can you block someone on instagram how to block someone on instagram who blocked you how to block someone on instagram without them knowing how to permanently block someone on instagram how to unblock someone on instagram that blocked you 2020 If you block someone on instagram can you see their profile what happens when you block someone on instagram what happens when you block someone on instagram but your profile is public
  • how-to-download-instagram-photos
    Download Instagram Photos on Your PC, Android, Mac or iPhone with These Easy Methods
  • how to hide posts on instagram
    One Easy Way to Hide Your Post from Someone on Instagram
  • change your instagram password
    Change Your Instagram Password in Two Simple Ways
  • how to recover instagram account
    2 Working Ways to Recover your Instagram Password
  • create a new instagram account
    Top 2 Ways to Create a New Instagram Account
  • how to get verified on instagram
    Want to Get Verified on Instagram? Here’s the Guide You Need
  • how to check who viewed my instagram profile
    Want to Know Who Visits your Instagram? Check Out the Steps
  • Increase your Instagram’s Business Page Followers
    Simple Ways to Increase your Instagram’s Business Page Followers
  • Subscribe to Our Newsletter
    • Blog
    Mail Id: info@getassist.net
