Facebook, one of the most popular social media platforms, is also a hub for hackers. This makes it even more significant to take proper security measures for such apps/platforms. And for this, two-factor authentication is something that we can rely on.
However, this additional layer of security asks for a security code sent to your device that we may or may not have access to all the time. But this doesn’t mean that without the code, it would be impossible to access your Facebook account. The Facebook code generator is the one that can rescue you here.
But before moving ahead, let’s get to know what this whole two-factor authentication process is and why we need a confirmation code for it.
Two-factor authentication or two-step verification is basically a security process that almost every major app follows, be it Instagram, a social media app, or Gmail, an emailing service. It provides better and enhanced protection to the user than single-factor authentication, where only one factor, i.e., The password, is used to access the account.
Two-factor authentication, on the other hand, adds another layer to the security of your account. With it, users will also need a security code sent to the device or email attached to the account. After the password, the code must be entered in the desired field, and only then will the user be able to access the account.
And now that users have two factors for authentication into their accounts, it is even harder for hackers to get into their accounts.
However, sometimes, when the users themselves don’t receive any confirmation code for their accounts, they may think that it is now impossible to log in to their Facebook accounts. But it’s actually the other way around; there is a way to bypass the Facebook code generator and get access to your account.
Now that you are aware of what two-factor authentication is and how the confirmation code works on Facebook let’s move ahead and learn more about the code generator Facebook and how to get a Facebook verification code without a phone.
Before getting to learn the Facebook code generator bypass process, you must have the two-factor authentication enabled on your Facebook account.
Enabling two-factor authentication is quite simple on Facebook. Visit Settings & Privacy section> Settings> Security and Login. There, under the two-factor authentication option, click on Edit. You might be asked to enter your password there.
Then, to enable two-factor authentication on Facebook, you will have to select the method you’d like Facebook to use for verification. You can either opt for authentication via SMS or a security key. Once selected, click Next.
If you choose verification via SMS, then Facebook will send you a six-digit security code on the phone number you entered; you can also use the same mobile number that is already added to your Facebook account. Once done, click on Finish.
And this is how you can enable two-factor authentication on your device. Let’s now learn about Facebook code generators.
Code generator lets you get access to your Facebook account when you have two-factor authentication enabled but can’t get access to the SMS code for it. So when you are traveling or don’t have access to the phone number associated with the account, a Facebook code generator can be really something that can save you; plus, it works on every operating system, be it Android or iOS.
But the question is, where is the Facebook code generator or how to find Facebook code generator? Here’s how.
To access code generator Facebook, launch the Facebook app on your device and visit the Settings & Privacy option and click on Code Generator. You’ll see the tool run the security codes every 30 or 60 seconds.
I guess that solved your problem: what is a code generator for the Facebook query, as you have learned all about Facebook code generators. But what if you lost your phone? What if you are somehow unable to receive the code? Can you access the code generator Facebook in any such situation? Of course, you can; let’s see how.
Most of us keep our valuable documents and files on our phones because that’s something that is going to stay with us all the time. This is why losing your phone can be a blunder. This goes the same with our social media accounts; we have set up our phones to be the key to our social media, and losing the phone means losing our accounts as well.
There are some workarounds that might help in such cases. Let’s have a look and learn about Facebook code generator bypass:
If you still have the access to the SIM you lost with the mobile phone, maybe your provider could provide you with another SIM with the same number then you are in luck.
Since Facebook can only use one number at a time for its two-factor authentication, you can’t add a secondary number for it.
From the screen asking for your login code, click on Need another way to Authenticate and there you will see an option to Text me a login code, click on it and you will receive the security code via SMS or through a call.
When you set up the two-factor authentication on your Facebook account, Facebook sends you a list of emergency codes that you can use in such cases. So if you have saved those codes then you are in luck again. So for your Facebook code generator not working issue, you can use one of those codes and you’ll be able to access your Facebook account again.
If you didn’t save those recovery codes as backup, be sure to note them down and take a screenshot on Facebook as the first thing when you get back your Facebook account.
Whenever you log in to your Facebook account from another device, Facebook asks if you want to remember the login details or not. If you tapped yes and the device still has your Facebook login credentials saved on it, you won’t need any confirmation code to log in to your Facebook account from that device.
You can also do that same with a browser that you have used before. Or try with another device that you used once, maybe you are still logged in from your laptop, computer, or tablet. All you have to do is get into your Facebook account once and after that, you can change the settings or even the password as per your wish.
If nothing worked out for you, then the last thing you can do is confirm your identity to Facebook so that they are sure of the account’s holder and let you in.
From the menu where you clicked on Need another way to authenticate, click on Get More Help and Facebook will help with further steps to recover your account.
You will be asked to enter your email address and attach a copy of your identity, it can be anything, a copy of your Passport, driver’s license, or anything. Once you are done with it, Facebook will email you further recovery steps.
You can apply the above steps from any device, from the app, or from the browser as well. All you have to do is visit https://m.facebook.com/ and log in to your account to get started with the Facebook code generator not working issue.
If you got your Facebook account back, but your phone is still lost where your account was logged in, there are certainly chances that your account might be accessible to someone else. In such a case, you should terminate the app’s Facebook session.
If you’re registered on your phone number and want to change the number associated with the Facebook account, visit Settings & Privacy> Settings> Mobile> Lost your phone. And there, click on Log out of the phone. From there, you can also remove the phone number that has been entered there.
Every other day there’s a new complaint from Facebook users because they have somehow lost their Facebook accounts. Well, that’s not something you can blame on someone, but most of the time users are unable to get back their accounts and have to end up creating new ones.
The reason behind that is they haven’t set the security measures properly, they do have a maintained profile, but security measures? That’s out of their syllabus. This is why it is utterly important to set up the profile properly and by setting up the profile I certainly don’t mean updating the profile picture on it, I mean taking proper security measures on it.
